Before we proceed with the installation of Centos Web Panel :
Requirements and instructions:
At least one static IP with your VPS. (Internal IP address are not supported by this control panel)
If you wanted to remove Centos Web Panel. You need to do a reinstall on your VPS.
Install on a fresh centos Operating system.
Login with your VPS as 'root' user.
First setup your hostname
# vim /etc/sysconfig/network
Change your hostname name within this file. Your hostname will be changed after next reboot.
Setup your nameserver IPs
# vi /etc/nameservers
In most of VPS this is configured already. If not enter the following lines.
nameserver 8.8.8.8
nameserver 8.8.4.4
Save the file" :wq! "
A static IP must be configured and provided by your VPS provider. If not contact your service provider.
We recommend to have at least a VPS with 4GB of ram to gain full functionality.
Use a Centos 6.5 version template available from your Control Panel.
During first installation run the following commands:
#yum install wget -y
#yum update -y
#reboot
After reboot, run the following commands:
#cd /usr/local/src
#wget http://centos-webpanel.com/cwp-latest
#sh cwp-latest
Reboot your VPS once more:
#reboot
Now your Centos Web Panel will be available at
http://<your static IP>:2030/
For example: http://192.168.0.2:2030/
1. Setup your shared IP after login.
2. Setup your one hosting package.
3. Setup your root email to receive emails.
Host your domains and enjoy!
nameserver 8.8.8.8
nameserver 8.8.4.4
#yum update -y
#reboot
#cd /usr/local/src
#sh cwp-latest
#reboot
