ModulesGarden
We are happy to announce release of another full-featured module - Proxmox Cloud For WHMCS.
Module allows your customers to create and manage their own virtual servers at virtual datacenters in your WHMCS client area! You set up the resource limits and your clients create servers within it!
Very interesting part of the module is Proxmox Addon where you can also monitor & manage your servers, IP addresses and clusters. Everything what you need, in one place.
Proxmox Cloud For WHMCS shows all its power and friendly user interface in the WHMCS client area. With our module your clients will be able to freely create and modify their servers. It also allows your customers to manage backups, access VNC console or view usage graphs.
Proxmox Cloud For WHMCS is a wonderful solution for both you and your customers. Make sure that you won't miss it!
Admin Area Features:
✔ Order Proxmox Cloud For WHMCS Now!
Do You Need More Information?
✔ Read More About Proxmox Cloud For WHMCS
Are You Looking For Complete Documentation?
✔ Visit Proxmox Cloud For WHMCS Wiki
Also make sure that you won't miss important update of module Proxmox VPS For WHMCS which allows you to automatically provision virtual servers to your customers as a ready products to purchase.
Changelog:
✔ Read More About Proxmox VPS For WHMCS 1.2
Today we have also released Advanced Billing For WHMCS 2.0.2 with complete support for Proxmox VPS For WHMCS and Proxmox Cloud For WHMCS modules. Our product will let you to charge customers based on the server resources used by them.
Changelog:
Do You Need Custom Software Development?
✔ Don't hesitate any longer! Contact us now!https://www.modulesgarden.com/order/request
- Create Server/User
- Suspend/Unsuspend Server/User
- Terminate Server/User
- View Server Status, Details And Statistics
- View Graphs (With Ability To Change The Time Scale of MRTG Graphs)
- Display Disk And Bandwidth Usage Of Each Product
- Possibility To Import IP To Hosting IP Addresses Table
- Possibility To Return IP To IP Addresses Pool
- Possibility To Add Additional IP To VM
- Servers List (VPS And Cloud)
- IP Management (Per Server)
- Clusters (Per Server)
- Create VM
- Boot Server
- Reboot Server
- Stop Server
- Shutdown Server
- Edit Server
- VNC Console
- Create Backups
- Restore Backups
- Schedule Backups
- Backup Jobs
- Backup Limits (Max Number Of Files & Max Size Of Files)
- Schedule Backup Limit (Max Number Of Files & Max Size Of File)
- Easy VM Upgrade/Downgrade
- Change Boot Order (KVM)
- Change ISO Image (KVM)
- Supports PVE And PAM Authentication
- Dynamically Chosen Server Resources While Ordering And Possibility To Upgrade Those Resources
- Integrated With Advanced Billing For WHMCS - Server Resource Usage Billing
- Multi-Language Support
- Supports Proxmox VE 3 and Later
- Supports IPv4 and IPv6
- Supports WHMCS V5 and Later
Changelog:
- Added automatic upgrade of Proxmox hosting accounts to version 1.2 of the module
- Added support for IPv6
- Added new custom fields: 'node', 'storage' and 'backup storage'
- Added 'Auto Node' option in module settings. If before account creation, option is set to 'Auto Node' then module will find the node with the most free space and create VM on that node
- Added automatic start of VM after creation of account
- Added feature allowing to import IP to hosting IP addresses table
- Added feature allowing to return IP to IP addresses pool
- Upgraded feature VM reinstall to new version supporting Auto-Node
- Added support for Linux PAM standard authentication (PAM) and Proxmox VE authentication server (PVE)
- Fixed bug with IP addresses not returned to pool if account creation failed
- Fixed bug with the console if server IP address is not filled
- Fixed bug with upgrading KVM without filled configuration options
- Many other minor fixes and improvements
Changelog:
- Added integration with module Proxmox Cloud For WHMCS: Disk Usage, Disk Size, Bandwidth IN, Bandwidth OUT, Memory Usage, Memory Size, Backups, CPU Number, CPU Usage
- Added integration with CPU Number and CPU Usage for module Proxmox VPS For WHMCS
- Fixed Backup Usage in module Proxmox VPS For WHMCS
