Project Management System
So, out of curiosity what's your preferred Project Management System?  Team management, work management, etc.
  • Like
Reactions: wdq
NodeBytes
Dedi Addict
I tend to use teambox a lot. It's not amazing, but it's free and gets the job done.
I will be moving to a self hosted solution soon, not sure which one yet.
Damian
I use MS Project, which is the only MS product that I truly like. I'm big on critical path management, which MS Project does extremely well.
bizzard
At DayScholars, we tried using Open Atrium, but it wasn't much effective. Now we use GroupOffice + git + wiki, which fulfill our present needs.
shovenose
WHMCS has a module of its own for this, especially if you want to integrate it with the customers billing. I've never tried it though so I do not know how good or bad it is.
Well, I was more thinking of web-facing scripts to manage projects, time worked, etc.  I guess the more proper term would be a collaborative suite.
ryanarp
Catalyst Host
I always liked using basecamp, but I haven't found anything self hosted that really meets my needs.
My own personal installation of Tree.io died a long time ago.  Let me just say that.  I'm looking for a new one.
vRozenSch00n
In the past my office used customized Lotus Notes + Domino, a very expensive suite. I think for a opensource application PHProjekt is a good choice.
