ModulesGarden
1. Theme Customization Tool → Now in our Proxmox VE and OpenStack Projects Modules!
Just last week, we introduced the Theme Customization Tool to the very first WHMCS module in our offer, our Proxmox VE bestseller. Now it's already available in another one, this time in OpenStack Projects For WHMCS!
What is the Theme Customization Tool?
In simple terms, the Theme system lets you adjust how the module looks from the inside. There's no need to work with CSS or look for any workarounds. You open the tool and change the interface as you go. You can make it softer or more distinct, depending on what feels right for your usual style of working.
There's a live preview built in, so you see every change right away, and you can choose between two modes depending on how much control you want.
The new OpenStack Projects For WHMCS 1.12.0 also brings a few additional updates. One of them is tracking incoming and outgoing network traffic per project, now available through new metrics. You can already use it to monitor usage, and billing based on this data will be added soon in a new version of Advanced Billing For WHMCS.
To make diving into this new release even more enjoyable, the module is currently available with a combined 30% discount!
Where do you want to start?
2. 40k Customers Promotion at ModulesGarden - 25% OFF Still Applies!
Whether it's your very first customer or your 40,000th, like in our case, the feeling is always the same. There's always a bit of pride in it, but also a lot of appreciation, because every customer adds something real to the story.
It doesn't matter if you're just starting or already running a more established WHMCS business. This is simply our way of saying thank you!
✦ Enjoy 25% OFF across Monthly, Annual, and One-Time WHMCS Modules! ✦
If you'd like to stay a bit longer and see how we got here, or just browse around, you're always welcome.
3. The Best Stacked Deal Right Now
Domain Orders Extended For WHMCS is currently available at over 30% OFF!
It's a solid tool for anyone who needs reliable DNS automation. You can provision DNS and rDNS zones, manage them through flexible packages, use access control tools, and give your clients the ability to manage their own zones and records directly in WHMCS.
We've also released updates for a few other WHMCS modules over the past few days, so it might be a good moment to catch up:
4. EasyDCIM 1.25.0
EasyDCIM v1.25.0 introduces a set of changes focused on improving how the platform works in real environments, especially as setups grow.
The system now runs fully on a Docker-based architecture, which makes deployments more consistent and easier to manage. Metrics handling has also been updated, with InfluxDB replacing RRD, so data stays efficient as it grows. On the operational side, there's a new Control CLI, which replaces older scripts with one consistent way to install, update, and maintain the system.
Power and capacity handling have also been improved, making it easier to work with different units without manual adjustments. On top of that, the dashboard and visuals across the application have been refreshed, making reports and infrastructure views easier to read.
Explore what's new in EasyDCIM 1.25.0!
5. PanelAlpha Multi Server 1.8.0
While a lot of recent attention has been on the Single Server edition, PanelAlpha Multi Server has also just been updated to version 1.8.0.
This release mainly focuses on how backups are created. Backups are now faster and less dependent on the hosting environment, which means they behave more reliably across different setups.
There are also a few additional changes. WP Cloud integration now supports cron jobs, making scheduled tasks easier to manage. Extendify automation has been expanded, and OpenLiteSpeed environments received a small update that improves everyday use.
See what's new in PanelAlpha Multi Server 1.8.0!
Need WHMCS Module Development For Your Business?
We can customize our modules to fit your exact needs or even create a completely new one from scratch to give your WHMCS platform an added boost!
- Discount Center For WHMCS – v2.0.6
- Product Linker For WHMCS – v2.1.3 [30% OFF!]
- Recurring Contract Billing For WHMCS – v2.3.1
4. EasyDCIM 1.25.0
