quick nameservers question
902moves
Is it possible to host your vanity nameservers on different dns management backends.
For example domains 1-10 are managed on dnsmadeeasy
domains 11-20 are managed on rage4
etc..
All would use the same vanity namerservers of ns1.imlearning.com, ns2...
I'm thinking this isn't possible due to needing to register the vanity ns on the multiple management sites and that may cause issues..
Thanks for any help you may throw my way as long as it doesn't take time out of your hands.
mojeda
As long as ns#.domain.tld point to dns servers I don't see why not?
As far as I know you only need to register your vanity nameserver at one location. Then you point the nameserver entries to the dns servers you use.
sv01
Slow but sure
I'm not sure, but I think that wont work.
how about  create different vanity ns for each provider ? for example ns1 and ns2 for dnsmadeeasy and dns1/dns2 for rage4
