Just finished the Unixbench with the overclocked RPi2 and it closes the gap quite bit between the stock RPi2 and the stock C1. The temperature sensor in the RPi2 showed 53.5'C when the test completed, my infrared thermometer shows the CPU/GPU chip at 34'C while it was on the last few tests.
I only ran the 4 CPU benchmark and skipped the single CPU test for the sake of time.
BYTE UNIX Benchmarks (Version 5.1.3)
System: jdraspbian: GNU/Linux
OS: GNU/Linux -- 3.18.7-v7+ -- #756 SMP PREEMPT Wed Feb 18 16:14:51 GMT 2015
Machine: armv7l (unknown)
Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
CPU 0: ARMv7 Processor rev 5 (v7l) (0.0 bogomips)
CPU 1: ARMv7 Processor rev 5 (v7l) (0.0 bogomips)
CPU 2: ARMv7 Processor rev 5 (v7l) (0.0 bogomips)
CPU 3: ARMv7 Processor rev 5 (v7l) (0.0 bogomips)
23:12:11 up 2 min, 1 user, load average: 0.11, 0.11, 0.05; runlevel 2
Benchmark Run: Thu Feb 19 2015 23:12:11 - 23:36:29
4 CPUs in system; running 4 parallel copies of tests
Dhrystone 2 using register variables 13115973.6 lps (10.0 s, 7 samples)
Double-Precision Whetstone 2208.3 MWIPS (9.9 s, 7 samples)
Execl Throughput 1555.2 lps (29.9 s, 2 samples)
Pipe Throughput 763366.7 lps (10.0 s, 7 samples)
Pipe-based Context Switching 136544.7 lps (10.0 s, 7 samples)
Process Creation 3225.8 lps (30.0 s, 2 samples)
Shell Scripts (1 concurrent) 2893.0 lpm (60.0 s, 2 samples)
Shell Scripts (16 concurrent) 190.2 lpm (60.6 s, 2 samples)
Shell Scripts (8 concurrent) 382.8 lpm (60.3 s, 2 samples)
System Call Overhead 1759180.8 lps (10.0 s, 7 samples)
System Benchmarks Partial Index BASELINE RESULT INDEX
Dhrystone 2 using register variables 116700.0 13115973.6 1123.9
Double-Precision Whetstone 55.0 2208.3 401.5
Execl Throughput 43.0 1555.2 361.7
Pipe Throughput 12440.0 763366.7 613.6
Pipe-based Context Switching 4000.0 136544.7 341.4
Process Creation 126.0 3225.8 256.0
Shell Scripts (1 concurrent) 42.4 2893.0 682.3
Shell Scripts (16 concurrent) --- 190.2 ---
Shell Scripts (8 concurrent) 6.0 382.8 638.0
System Call Overhead 15000.0 1759180.8 1172.8
System Benchmarks Index Score (Partial Only) 548.2
Now I'm going to switch off my laptop and use my RPi2 for as long as possible to see what kind of desktop replacement it has the potential for.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
