Running your own radio station recorder
I like to listen to some radio stations but there are some shows that have bad airtimes.
So my Raspberry Pi (with an attached 500GB usb drive) is my personal radio recorder.
1. How do you get the stream urls of your favorit radio station?
Visit listenlive.eu to get a quite complete list of all radio stations per country.
This site is providing all links for the different bitrates too.
2. Install streamripper
sudo apt-get install streamripper
3. Run streamripper
streamripper http://lyd.nrk.no/nrk_radio_p1_finnmark_aac_h.m3u -d /home/wlanboy/radio/ -l 7200
The pattern is:
streamripper [url of stream] -d [folder to save musik files] -l [time in seconds to record music]
Last optional step is to setup a cronjob to call streamripper.
Each radio station will get a own sub folder.
I've been using streamripper for a long time now.
Only problem I have with it is with network hiccups.  When that happens, the recording splits into another file.  So a single recording might end up with 2-4 different files.
Any idea of how to prevent that and have it run a continuous single file in these instances?
There are two options:
  1. -A
    -A - Don't write individual tracks
    -m timeout     - Number of seconds before force-closing stalled conn
  2. -p
    -p url         - Use HTTP proxy server at <url>
I use 1) to ensure that one show is stored in one file and that small timeouts are ignored.
Option 2) might be an option if you rely on a proxy which does support caching/buffering.
@wlanboy,   I saw those options.   Will tinker with my script / wrapper for streamripper to see if any of these correct the misbehaving.
Off to edit :)
  1. -A
  2. -p
Well, I already  -m  timeout in my wrapper script.  Bounced the time limit up to 60 seconds.  Ideally that helps.
I had -a in options, but not -A which does entirely different thing.   Someone wasn't thinking with same letter option there...
Throwing this in the script too:
--xs-none
--xs-none   (Don't search for silence)
Silence is unimportant since I am not using Streamripper to rip individual tracks down to different files but instead ripping entire shows (i.e. one hour or multi hour production inclusive of commercials).
I do have the same problem that streamripper sometimes starts stuttering. I will try your parameters.
