Slow upload speed
libro22
I got a dedi box in LA a few weeks ago and I notice that it has slow upload speed.
From an Orlando VPS, it can only seldom hit 1Mb/s. I'm trying to upload from another LA VPS (different datacenter) and highest I can get is 0.7Mb/s.
Btw, I have 100mbps port. Any tips on diagnosing this issue?
Thank you.
I use iperf for this type of testing:
| Server A +---------------------- + Server B +
IP:192.1.1.1 IP:192.2.2.2
iperf server iperf client
And running:
iperf -s -B 192.1.1.1
iperf -c 192.2.2.2 -d -t 60 -i 10
Parameters:
-s : Run in server mode
-B IP : Bind to IP
-c IP : Run in client mode, connecting to IP
-d : Test bidirectional test at the same time
-t 60 : Time in seconds to transmit for (default 10)
-i 10 : Pause n seconds between periodic bandwidth reports
Typically, I place a file on such a server, behind say Nginx or your favorite web server.  A true random data "speedtest" file.  A 1GB file usually is big enough unless we are testing a very fast upstream.
Testing occurs with wget mainly.
If single threaded wget doesn't seem speedy enough.   I move over to axel for a multithreaded download instead and compare.
While wonky speeds like this are too common, it is somewhat rare to see in same city/region.  I do traceroutes between the two end points to see which upstreams are involved.
After doing all that, for sanity sake, I compare by testing a speed test file on the same network as my dedicated server.
libro22
Traceroutes are normal as verified with provider. We both tried speedtest files, seems to be okay. <= 1Mbps from Orlando and Texas to LA, others go beyond 5Mbps.
Will try iperf and check.
