Spider Duo
Munzy
I have been trying to re-install my OS over a Spider DUO, but to my misfortune it won't accept my debian net boot ISO. I have tried SAMBA as well, and direct CD, but nothing works. It always says "Disconnected by device". Does anyone have any suggestions????
Mun
Munzy
Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You!
I looked all over and found nothing about a fix :((((
So...
Did that fix it?
I find they are horrible when you are located 350-400ms from the server, KVM has never worked on the spiders for EU servers in my case. Double typing etc.
There might be some firmware or configuration thats not set, but yeah... Im not a fan.
This is why I have this amazing system of...
Using a remote desktop session to load up the KVM.
X2Go is REALLY helpful for this.
For java & a real browser? or what?
Probably the best auto-install script would be to disable the IE enhanced security mode....
iWF-Jacob
Man, those damn Spiders are just a total PITA. We have them at each of our locations, and half of the time they crap out -- but we've never found a better replacement. Does anyone know of one?
Also, @Munzy -- if it ever just glitches out and you cannot access the HTTP interface, you can actually SSH in to those devices (use your admin user/pass) and then issue the command "admin reboot" which reboots them as well.
qps
The SpiderDuo is a bit better than the Spider.  Not really another replacement out there that is as inexpensive and supports virtual media.
