bytebitter
Hi All,
After months of lurking (sounds horrible that...) both on LEB before the 'fall out' & then on here, I've finally got round to my first post
I notice that many of the LEB crowd that I got to 'know' have migrated over here & so I thought here was a good place to start.
Here goes: I'm looking for a low end vps to serve two functions, one a Minecraft server for my nephew & a couple of his friends & the other, a work-around for a university proxy block to XBox Live. I'm thinking a vpn on the latter assuming the uni proxy doesn't do nasty port blocking. As I have no familiarity with Minecraft I don't know what spec of vps would be required but don't expect it would need anything fancy just for a couple of them. As for blocking Xbox Live, I'm a little surprised at that as I didn't think it was very b/w intensive.
I would prefer Xen, KVM over OpenVZ with a Debian image loaded.
Any suggestions on access restriction for the Minecraft bit welcomed! Thinking of a DynDNS style domain name for each of the users as they're on dynamically assigned IPs & then allowing access only via those domains through the firewall. That way I might not get moaned at when someone comes & nicks their gold(?) & is basically obnoxious &or verbally repellent
OK, over to you!
Looking forward to any offers & or advice, many thanks.
Regards,
Mark.
OK, over to you!
Regards,
Mark.
