Vultr - What hardware exactly are they running on their SSD nodes?
Someone was poking around Vultr tonight and looking at CPU related info.   Reason why?   Hardware builds there are clouded in mystery.
cat /proc/cpuinfo outputs semi-vague info.... there at Vultr...
The Storage VPS offering is a match on output for:
 Intel® Xeon® CPU E5506 @ 2.13GHz [Family 6 Model 26 Stepping 5
The standard SSD VPS nodes are far more funkier.
cat /proc/cpuinfo  spits out usable data, but namely the STEPPING value of 1, isn't valid.   I cannot match the details to anything.
However,  cpuid, included in Debian is happy to make some usable hay of the matter.  It can't identify the CPU either and believes there are a total of 16 cores in that server.
I have my money on this being an i7-2600, but that family doesn't do dual physical CPUs you would need to get up to 16 cores...
Perhaps someone else has some ideas :)
The cat /proc/cpuinfo from the SSD node:
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 60
model name : Vultr Virtual CPU 2
stepping : 1
microcode : 0x1
cpu MHz : 3392.140
cache size : 4096 KB
physical id : 0
siblings : 1
core id : 0
cpu cores : 1
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
flags : fpu de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx rdtscp lm constant_tsc up rep_good nopl pni pclmulqdq ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx hypervisor lahf_lm xsaveopt fsgsbase smep erms
bogomips : 6784.28
clflush size : 64
cache_alignment : 64
address sizes : 40 bits physical, 48 bits virtual
power management:
cpuid output:
CPU 0:
   vendor_id = "GenuineIntel"
   version information (1/eax):
      processor type  = primary processor (0)
      family          = Intel Pentium Pro/II/III/Celeron/Core/Core 2/Atom, AMD Athlon/Duron, Cyrix M2, VIA C3 (6)
      model           = 0xa (10)
      stepping id     = 0x3 (3)
      extended family = 0x0 (0)
      extended model  = 0x1 (1)
      (simple synth)  = Intel Core (Bloomfield) / Xeon (Bloomfield / Gainestown), 45nm
   miscellaneous (1/ebx):
      process local APIC physical ID = 0x0 (0)
      cpu count                      = 0x10 (16)
      CLFLUSH line size              = 0x8 (8)
      brand index                    = 0x0 (0)
   brand id = 0x00 (0): unknown
   feature information (1/edx):
      x87 FPU on chip                        = true
      virtual-8086 mode enhancement          = false
      debugging extensions                   = true
      page size extensions                   = true
      time stamp counter                     = true
      RDMSR and WRMSR support                = true
      physical address extensions            = true
      machine check exception                = true
      CMPXCHG8B inst.                        = true
      APIC on chip                           = true
      SYSENTER and SYSEXIT                   = true
      memory type range registers            = true
      PTE global bit                         = true
      machine check architecture             = true
      conditional move/compare instruction   = true
      page attribute table                   = true
      page size extension                    = true
      processor serial number                = false
      CLFLUSH instruction                    = true
      debug store                            = false
      thermal monitor and clock ctrl         = false
      MMX Technology                         = true
      FXSAVE/FXRSTOR                         = true
      SSE extensions                         = true
      SSE2 extensions                        = true
      self snoop                             = false
      hyper-threading / multi-core supported = true
      therm. monitor                         = false
      IA64                                   = false
      pending break event                    = false
   feature information (1/ecx):
      PNI/SSE3: Prescott New Instructions     = true
      PCLMULDQ instruction                    = false
      64-bit debug store                      = false
      MONITOR/MWAIT                           = false
      CPL-qualified debug store               = false
      VMX: virtual machine extensions         = false
      SMX: safer mode extensions              = false
      Enhanced Intel SpeedStep Technology     = false
      thermal monitor 2                       = false
      SSSE3 extensions                        = true
      context ID: adaptive or shared L1 data  = false
      FMA instruction                         = false
      CMPXCHG16B instruction                  = true
      xTPR disable                            = false
      perfmon and debug                       = false
      process context identifiers             = false
      direct cache access                     = false
      SSE4.1 extensions                       = true
      SSE4.2 extensions                       = true
      extended xAPIC support                  = true
      MOVBE instruction                       = false
      POPCNT instruction                      = true
      time stamp counter deadline             = false
      AES instruction                         = false
      XSAVE/XSTOR states                      = false
      OS-enabled XSAVE/XSTOR                  = false
      AVX: advanced vector extensions         = false
      F16C half-precision convert instruction = false
      RDRAND instruction                      = false
      hypervisor guest status                 = true
   cache and TLB information (2):
      0x7d: L2 cache: 2M, 8-way, sectored, 64 byte lines
      0x30: L1 cache: 32K, 8-way, 64 byte lines
      0x2c: L1 data cache: 32K, 8-way, 64 byte lines
   processor serial number: 0001-06A3-0000-0000-0000-0000
   deterministic cache parameters (4):
      --- cache 0 ---
      cache type                           = data cache (1)
      cache level                          = 0x1 (1)
      self-initializing cache level        = true
      fully associative cache              = false
      extra threads sharing this cache     = 0x0 (0)
      extra processor cores on this die    = 0xf (15)
      system coherency line size           = 0x3f (63)
      physical line partitions             = 0x0 (0)
      ways of associativity                = 0x7 (7)
      WBINVD/INVD behavior on lower caches = true
      inclusive to lower caches            = false
      complex cache indexing               = false
      number of sets - 1 (s)               = 63
      --- cache 1 ---
      cache type                           = instruction cache (2)
      --- cache 2 ---
      cache type                           = unified cache (3)
      cache level                          = 0x2 (2)
      ways of associativity                = 0xf (15)
      number of sets - 1 (s)               = 4095
   hypervisor_id = "KVMKVMKVM   "
   hypervisor features (0x40000001/eax):
      kvmclock available at MSR 0x11          = true
      delays unnecessary for PIO ops          = true
      mmu_op                                  = false
      kvmclock available a MSR 0x4b564d00     = true
      async pf enable available by MSR        = true
      steal clock supported                   = true
      guest EOI optimization enabled          = true
      stable: no guest per-cpu warps expected = true
   extended feature flags (0x80000001/edx):
      SYSCALL and SYSRET instructions        = true
      execution disable                      = true
      1-GB large page support                = false
      RDTSCP                                 = false
      64-bit extensions technology available = true
   Intel feature flags (0x80000001/ecx):
      LAHF/SAHF supported in 64-bit mode     = true
      LZCNT advanced bit manipulation        = false
      3DNow! PREFETCH/PREFETCHW instructions = false
   brand = "Vultr Virtual CPU 1"
   L1 TLB/cache information: 2M/4M pages & L1 TLB (0x80000005/eax):
      instruction # entries     = 0xff (255)
      instruction associativity = 0x1 (1)
      data # entries            = 0xff (255)
      data associativity        = 0x1 (1)
   L1 TLB/cache information: 4K pages & L1 TLB (0x80000005/ebx):
   L1 data cache information (0x80000005/ecx):
      line size (bytes) = 0x40 (64)
      lines per tag     = 0x1 (1)
      associativity     = 0x2 (2)
      size (Kb)         = 0x40 (64)
   L1 instruction cache information (0x80000005/edx):
   L2 TLB/cache information: 2M/4M pages & L2 TLB (0x80000006/eax):
      instruction # entries     = 0x0 (0)
      instruction associativity = L2 off (0)
      data # entries            = 0x0 (0)
      data associativity        = L2 off (0)
   L2 TLB/cache information: 4K pages & L2 TLB (0x80000006/ebx):
      instruction # entries     = 0x200 (512)
      instruction associativity = 4-way (4)
      data # entries            = 0x200 (512)
      data associativity        = 4-way (4)
   L2 unified cache information (0x80000006/ecx):
      associativity     = 16-way (8)
      size (Kb)         = 0x200 (512)
   L3 cache information (0x80000006/edx):
      line size (bytes)     = 0x0 (0)
      lines per tag         = 0x0 (0)
      size (in 512Kb units) = 0x0 (0)
   Advanced Power Management Features (0x80000007/edx):
      temperature sensing diode      = false
      frequency ID (FID) control     = false
      voltage ID (VID) control       = false
      thermal trip (TTP)             = false
      thermal monitor           = false
      software thermal control (STC) = false
      100 MHz multiplier control     = false
      hardware P-State control       = false
      TscInvariant                   = false
   Physical Address and Linear Address Size (0x80000008/eax):
      maximum physical address bits         = 0x28 (40)
      maximum linear (virtual) address bits = 0x30 (48)
      maximum guest physical address bits   = 0x0 (0)
   Logical CPU cores (0x80000008/ecx):
      number of CPU cores - 1 = 0xf (15)
      ApicIdCoreIdSize        = 0x0 (0)
   SVM Secure Virtual Machine (0x8000000a/eax):
      SvmRev: SVM revision = 0x0 (0)
   SVM Secure Virtual Machine (0x8000000a/edx):
      nested paging                 = false
      LBR virtualization            = false
      SVM lock                      = false
      NRIP save                     = false
      MSR based TSC rate control    = false
      VMCB clean bits support       = false
      flush by ASID                 = false
      decode assists                = false
      SSSE3/SSE5 opcode set disable = false
      pause intercept filter        = false
      pause filter threshold        = false
   NASID: number of address space identifiers = 0x0 (0):
   (multi-processing synth): multi-core (c=16)
   (multi-processing method): Intel leaf 1/4
   (APIC widths synth): CORE_width=4 SMT_width=0
   (APIC synth): PKG_ID=0 CORE_ID=0 SMT_ID=0
   (synth) = Intel Core (Bloomfield) / Xeon (Bloomfield / Gainestown), 45nm
rds100
i7-2600 should have 8MB cache, not 4MB.
edit: scratch that, the virtual CPU isn't reporting the cache size of the physical CPU.
Awmusic12635
Does it really matter? Seems you are making a big deal out of nothing really. Some companies disclose info, others don't.
Amitz
I think it is quite interesting. Vultr lies about being multihomed (at least they are not in most locations), plays funny games when it comes to the question whether they use any RAID at all and having everything on non-enterprise (desktop) hardware would just round out the picture.
If it works well for your needs, I don't think it particularly matters what is powering it, though I do understand being curious.
Isn't their cloud utilizing some form of xen or kvm virtualization? Is the ability to update the 'model name' of the physical cpu available in each?
Choopa and UnmeteredServers sell E5506...the storage server
Gameservers.com sells E3-1240v2 and Choopa/ReliableServers/Constant.com/UnmeteredServers sell E3-1240v3. Vultr uses Choopa (NJ) and Gameservers (everywhere else) locations.
They don't sell i7-2600...
CPU ID info is normally just fine and clear....  This seems like someone has gone out of the their way to do something out of ordinary.   Unsure if it works for me, as I am not a customer ;)
I'd ask in pre-sales but:
https://discuss.vultr.com/discussion/479/raid
https://discuss.vultr.com/discussion/473/storage-node-redundancy-info-required
See how those went with others...
And when talking about cores vs. threads vs. imaginary CPUs... well:
https://discuss.vultr.com/discussion/219/cpu-cores-and-hyperthreaded
Maybe they don't ;)   They do sell among their brands or have different i7 models.
Reliablesite has this:
Intel Core i7 47708 x 3.4 ghz8GB - 32GB4 x SSD/HDD10 TB1 Gbps DedicatedSale! - $89/m
Choopa owns ReliableServers.com. ReliableSite.net isn't one of their companies (although it does colo with them).
Vultr's newer nodes are 3.5MHz which is probably E5-1650v2/3
Attached is the /proc/cpuinfo from an OpenVZ container that I have that's slabbed inside a Vultr VM in Tokyo, Japan.  This is a lowendspirit.com vps if that matters.  Some info from it:
cpu family    : 6
model        : 60
stepping    : 1
cpu MHz        : 3600.010
I don't know if the cpu family/model identifies a specific Intel CPU.
jcpu.txt
XFS_Duke
XFuse Solutions, LLC
The world may never know their true ways of doing business. As most say, if it's reliable and stable, why worry. The main reason I'd worry is that I like to know what my sites or services are running on. I guess it is what it is... Some companies don't give out information and some should give out less information, like if your nodes run on Atom CPU's or i7's.
Kris
Single homed setups piggybacking off GameServers? Yup
Probably desktop E3 hardware? Yup
RAID - Hopefully?
I have a few test boxes there and they are pretty fast. The support leaves a lot to be desired, and seems like an afterthought or their parent company / GameServers.com techs answering when they can.
Just make many, many backups and you should be fine.
Going to be an interesting mess when a drive or node dies however.
cpu family    : 6
model        : 60
stepping    : 1
cpu MHz        : 3600.010
jcpu.txt
There we are with Family 6 Model 60 Stepping 1 again...
Someone find me something that matches that :)  I didn't find anything that did yesterday.
The Family and Model part match i5, i7 and E3...  The Stepping of 1 doesn't exist though.
@willie  can you install cpuid and run that for me to get output?  Reason why is I see 3.6Ghz there.  Other node I saw output from was a 3.3x Ghz...  More sample sets and ideally some leakage from cpuid might identify something.  Leaning towards another i7 variation on the Tokyo box.
Problem is E3 or i7 makes no matter - neither chipset has 16 cores even though CPUID is saying the hardware believes it does.
Dylan
Well hey, DigitalOcean recently stopped masking their CPUs, and Vultr seems real intent on copying DO... so maybe we'll know for sure soon?  :rolleyes:
Oh really, did DigitalOcean :) ?   I had to go check and I am not liking what I see in DigitalOcean land either...
cat /proc/cpuinfo
processor : 0
cpu family : 6
model : 2
model name : QEMU Virtual CPU version 1.0
stepping : 3
microcode : 0x1
cpu MHz : 1999.999
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 4
wp : yes
flags : fpu de pse tsc msr pae mce cx8 apic mtrr pge mca cmov pse36 clflush mmx fxsr sse sse2 syscall nx lm up pni vmx cx16 popcnt hypervisor lahf_lm
bogomips : 3999.99
clflush size : 64
power management:
Family 6, Model 2, Stepping 3...  What the heck CPU is that?!?!?!  I can't identify it.
So off to see CPUID....
Vendor ID: "GenuineIntel"; CPUID level 4
Intel-specific functions:
Version 00000623:
Type 0 - Original OEM
Family 6 - Pentium Pro
Model 2 -
Stepping 3
Reserved 0
Extended brand string: "QEMU Virtual CPU version 1.0"
CLFLUSH instruction cache line size: 8
Feature flags 078bfbfd:
FPU    Floating Point Unit
DE     Debugging Extensions
PSE    Page Size Extensions
TSC    Time Stamp Counter
MSR    Model Specific Registers
PAE    Physical Address Extension
MCE    Machine Check Exception
CX8    COMPXCHG8B Instruction
APIC   On-chip Advanced Programmable Interrupt Controller present and enabled
SEP    Fast System Call
MTRR   Memory Type Range Registers
PGE    PTE Global Flag
MCA    Machine Check Architecture
CMOV   Conditional Move and Compare Instructions
FGPAT  Page Attribute Table
PSE-36 36-bit Page Size Extension
CLFSH  CFLUSH instruction
MMX    MMX instruction set
FXSR   Fast FP/MMX Streaming SIMD Extensions save/restore
SSE    Streaming SIMD Extensions instruction set
SSE2   SSE2 extensions
TLB and cache info:
7d: unknown TLB/cache descriptor
30: unknown TLB/cache descriptor
2c: unknown TLB/cache descriptor
Processor serial: 0000-0623-0000-0000-0000-0000
That processor serial # isn't real happy findings.
Think Intel Core 2 Duo.
