I said it wouldn't. It would check only the IPs which you tell it to check. However, I do think that's a good idea and will add the functionality in an hour or two, when I wake up a bit.Is it going to check the IP's in WHMCS that are against products/services or not?
If not, what's the point in involving WHMCS? If it is, then what about extra IP addresses?
This is like pulling teeth.
http://puu.sh/cYrKu/f197ab65f0.png
http://puu.sh/cYrNz/b1234bfbd6.png
http://puu.sh/cYrOG/2c4a12f06a.png [There will be a second template file which will display the data a bit differently, should you choose to use it that will display as 127.0.0.0/24 and 0/256 dirty IPs (two columns instead of four)]
More screenshots later. Dirty IPs will be listed on a separate page. Logs will be kept of actions, which IPs were blacklisted and when, by which clients, et cetera.
