SolusVM Patch - Solved Server Rebuild Problem Returning Error: 'Invalid Template'
Hello guys, we have just received a reply from SolusVM support with solution to common problem. This should be helpful for some of you.
{edited}
Please don't link to your forums like that. If you have information to share then by all means share it here.
Quexis
From the forum in question (which I won't be linking to, due to MartinD's post above):
Important information that we received from SolusVM support. Will be helpful for many, no doubt.
This is a solution for the problem with server rebuild returning 'Invalid Template' error.
"Here is the patch you need to run on the master node in SSH:
wget http://files.soluslabs.com/solusvm/fixes/api_vserver_rebuild.txt -O /usr/local/solusvm/includes/api/api_vserver_rebuild.php
This will allow you to rebuild KVM virtual servers via the API. Example output if using the json return values would be:
{"status":"success","statusmsg":"Virtual server is being rebuilt","rootpassword":"6axLkKpi","information":"Blah\nBlah\nBlah"}Solution works on SolusVM beta only.According to the answer received from SolusVM support, it will be included in the stable version.
Understood, here it goes:
A few hours ago we received important information from SolusVM support regarding problem mentioned in the topic. This information should be helpful for some of you. This is a solution for the problem with server rebuild returning 'Invalid Template' error.
{"status":"success","statusmsg":"Virtual server is being rebuilt","rootpassword":"6axLkKpi","information":"Blah\nBlah\nBlah"}"
According to the answer received from SolusVM support, this solution works only on SolusVM beta and it will be included in the stable version.
rsk
Thanks for this, really. However, I guess we still have to wait for solus to release it in the stable version so we can put it into use. No BETA for me.
