Any free or low priced WHMCS module for cloud VPS automation?
perennate
Lobster supports OpenStack backend
https://github.com/LunaNode/lobster
It's sort of an hourly billing panel built on top of virtual machine management systems.
There is plans for a WHMCS module to add credit at https://github.com/LunaNode/lobster/issues/26, if this would work for your purpose then you should reply in that issue.
Otherwise all of the cloud software you mentioned provide a strong and easy to use API, so it isn't difficult to create a WHMCS module. It's actually best that you write your own module since that allows you to adapt it to fit to your specific billing model, which a third party module might not support.
perennate
The WHMCS integration was implemented in Lobster (module for hosting account category that will register accounts with Lobster, add credit, and authenticate via link in service page).
BlaZe
ModulesGarden have a module for Proxmox Cloud VPS with total automation. I use their Proxmox VPS module & would recommend it :D
manish
Hello Everyone,
Are you looking for any free or low priced WHMCS module for cloud VPS automation?
If you want to improve your online business in the market. Then choosing the right cheap priced cloud VPS automation is the very important part.
Top Free or Low Priced Cloud VPS Hosting Company
  • DomainRacer –VPS Hosting With Extra Ordinary Features
  • DedicatedCore – Reputed Very Low-Cost Service
Now, Don’t waste your time for searching another low price VPS hosting company. You can go with DomainRacer and DedicatedCore hosting services Because both provide good plans or services.
