Does GVH kill torrent processes?
Status
Not open for further replies.
dzchimpo
Also set up a cron:
* * * * * /bin/bash /root/test.sh
with:
cat /root/test.sh
#!/bin/bash
dt=`date`
process=deluged
if ! [[ `ps ax | grep -v grep | grep $process` ]]
then
        dm="daemon was not running at "$dt
        echo $dm | mutt -s "Daemon killed test" -- me@some
else
    echo "daemon is already running"
fi
exit
GVH-Jon
Banned
If you're peaking near the point of abuse then your process may be killed as a courtesy as opposed to suspension being issued, torrent processes are not specifically targeted.
Virtovo
Hi Jon,
I thought that might be the case hence my questioning.  Are you able to give a little more insight into what metric you are measuring 'abuse' on?
The Nodewatch alert level for [insert abusive activity name] would be my guess...
I used transmissions without issue until I was terminated for an unspecified reason in their catch all clause.
Mun
That's what you get for signing up with a host whose CEO spends half his life in front of the judge.
Case Numbers For
LANCE A JESSURUN, born in 1992
     Case Number    Name    Status    Date Filed
Select    2014TR005362    LANCE A JESSURUN    Open    11-MAR-14
Select    2014TR005361    LANCE A JESSURUN    Open    11-MAR-14
Select    2013TR027472    LANCE A JESSURUN    Closed    18-NOV-13
Select    2013TR027471    LANCE A JESSURUN    Closed    18-NOV-13
Select    2013TR019739    LANCE A JESSURUN    Closed    16-AUG-13
Select    2013TR019738    LANCE A JESSURUN    Closed    16-AUG-13
Select    2013TR017889    LANCE A JESSURUN    Closed    25-JUL-13
Select    2013TR017888    LANCE A JESSURUN    Closed    25-JUL-13
Select    2012TR022139    LANCE A JESSURUN    Closed    28-SEP-12
Select    2012TR022138    LANCE A JESSURUN    Closed    28-SEP-12
Select    2010TR011987    LANCE A JESSURUN    Closed    17-MAY-10
Select    2010TR011986    LANCE A JESSURUN    Closed    17-MAY-10
Status
