Forum downtime / maintenance RFO
Yeah, lots of posts no appearing in public.
How you are able to get it figured out and documented for long term sanity.
The data still exists, so it's not lost. Just not viewable. I'm waiting for IPB to get back to me, as I'd like to manually restore any lost discussion that's not viewable currently.
None of the posts have been lost so don't worry. It's just IPB and its archive feature that appears to have 'removed' them from thread visibility.
They call that a "feature"?  That isn't a feature.
Why would anyone running a site want to see their posts disappear from their site?
Well, the feature is to archive things based on certain criteria. The settings were incorrect (my fault) so it archived damn near everything. While UNarchiving posts, it won't complete. Then the CVPS thread (and that thread only, I believe) has lost half of it's viewable content. The content still exists, just not viewable now...
Further more the daily post stats are screwed up in the backend and don't represent the true daily post counts anymore.
I could run some DB tools from the backend to rebuild/recount/redo stuff but waiting to hear back from IPB before I do anything.
mojeda
@manndude, you can export mysql database remotely via ssh as long as the server has mysql-client installed :)
mysql -h mysql.host.tld -u USERNAME -pPASSWORD DATABASE >> database.sql
Something like that at least, I don't see why this wouldn't work with BuyVM's Shared SQL.
We did this yesterday morning. The issue isn't importing the DB now, the issue is pulling specific data from it and restoring some posts individually.
JDiggity
Forum was down for several hours while Martin and I got everything sorted. In short, we had to restore a DB from about 5AM EST, I put the site in matineance mode around 6AM(ish) so it was a slow period, not many (if any) posts were lost.
Chat log from IRC because I am tired:
11:40 <@Manndude> Well here is the series of events
11:40 <@Manndude> Saturday night, MannDude had some beers
11:40 <@Manndude> NOT A LOT
11:40 <+TheHackBoxPie> oh crap
11:40 <+TheHackBoxPie> he franned it
11:41 <@Manndude> The post stats in the backend were broke. They were displaying the wrong numbers for the days. It was saying that prior to the 18th the forum was getting liek 40 posts a day. The 18th we had 777 posts exactly, I remember because it was 777
11:41 <@Manndude> Soooo
11:41 <@Manndude> I do a DB dump, and THEN run the optimize tables tool
11:41 <@Manndude> Things were faster, but I noticed some threads were archived that should not have been
11:42 <@Manndude> So I tried to fix that
11:42 <@Manndude> By turning off archiving and setting it to UNarchive anything
less than 365 days old (everything)
11:42 <@Manndude> then I noticed the CVPS thread went from 700+ posts to 350 something
11:42 <@Manndude> So locked her down
11:42 <@Manndude> Said 'nuh uh, not today'
11:42 <@Manndude> And started drinkign coffee
11:43 <@Manndude> But the DB dump was too big for PMA which is my only point of access to the remote server and doing it via SSH took a long time
11:43 <@Manndude> plus there was an hour or two trying to figure out how to proceed without doing a DB restore
11:44 <@Manndude> That's the RFO
As of now, 11:50 GMT-5, the board is currently unarchiving threads and will be doing so for some time.
Screenshot - 06232013 - 11:59:14 AM.png
That is the screenshot of the post stats now. That is completely wrong and much lower than what it should be. The 18th we had exactly 777 posts.
I believe this has to do with all the thread archiving. I enabled archiving but didn't specify the proper settings, thus damn near everything archived. I goofed, it was my fault. I'm paying the price for it now at noon with no sleep. Everything should be unarchiving now.
The way this works is there is a scheduler that runs on it's own unknown (to me) interval that does this in bulk, 250 at a time. It looks like it took quite some time for everything to archive, so I suspect it'll take quite some time for everything to UNarchive.
That's the RFO for now.
If you set the upload file size larger and the php timeout to a longer time then this should not be a problem.
I believe it was this part:
MySQL is offsite/remote on a shared SQL server. I can not adjust those settings myself. Had to import via SSH which for some reason was unreasonably slow. Took several hours for a 90MB DB, and the import failed the first time as the connection dropped mid-way.
