How to Connect a Domain with your VPS - The Easy Way
Gaiacom_LC
When setting up a new VPS, one of the most common tasks is to link a domain name. The process is roughly the same as with a shared hosting account, although a VPS may or may not come with ready-made nameservers available.
Often, you will need to configure your own nameservers on a VPS. To avoid this, and get started as quickly as possible, we will use an easy method to point a domain to a VPS (or other server).
Requirements:
  • Domain name registered (.com, .net, etc.)
  • Using default nameservers and DNS system of the registrar (default settings).
  • IP address of your VPS or server.
Here are the instructions:
- Log in to your domain registrar*(where your domain was purchased), for example Namecheap or GoDaddy.
- Locate the section for adding or modifying DNS Zones. Look for "Records" or "Zones."
- Choose your domain (if not already selected), and proceed to Add a new DNS record.
- Add a record of type "A" (Address Record). Fill in the fields like this:
Subdomain: @
Record/Host: 185.185.185.21 (Your server's IP address)
- Additionally, add a CNAME record for subdomain "www" pointing to host "domain.com" (your domain) to enable use of www.yourdomain.com.
Save the new settings, and exit. That's it!
The crucial step is pointing "@", which stands for your root domain 'domain.com', to the IP address of your VPS. The registrar's nameservers will now host this record, and all traffic to your domain will be automatically routed to the server IP address. It may take up to 12-24 hours for the new DNS changes to propagate around the Internet, so you may not see the change take effect immediately.
Note that if your registrar's format does not allow "@", you can usually leave the 'subdomain' field empty, because you are entering a record for the root domain.
Archived in our VPS Hosting Blog.
Cloudflare and Rage4 are also quite simple and fast to use to get setup. DNS is just one of those things I don't really care to host myself anymore. Used to run a small DNS cluster but I'd rather let professionals handle it now. :)
Gaiacom_LC
Agreed. Cloudflare would definitely be one of my first recommendations for outside DNS.
IntegralHost
Note that, if you are using registrar name servers. You should create all your DNS records such as ( A, MX, NS, CNAME... ) at registrar end. I noticed many of them always missing to create MX record and facing mail issues.
SentinelTower
Nice tutorial which should help most beginners.
Maybe you should add how to add MX records as some users may want their email delivered to their VPS as well.
