HyperVM is dieing, Feathur takes over (BlueVM Control Panel Change)
BlueVM
Good evening,
Over the next few weeks we will begin moving from HyperVM to Feathur for our OpenVZ customers. As such we've defined dates for the estimated move.
Buffalo, New York => July 21 - July 28
Atlanta, Georgia => August 1 - August 5
Dallas, Texas => August 8 - August 14
Chicago, Illinois => August 16 - 21
Los Angeles, California => August 22 - 27
Kansas City, Missouri => August 27 - 29
These dates are rough estimates of when we will transfer the vps over to our new control panel. We expect each VPS to go offline for a few seconds during the transfer, however VPS may go offline for up to 15 minutes (one-time). Once your VPS has been transfered to the new control panel you will be emailed a one-time activation link to set your password for Feathur. Your VPS along with all of its files, settings, etc... will remain exactly the same and your IP will NOT change.
We expect this process to go quickly and to be an easy transition, however if for any reason you are having issues feel free to contact our support team.
Best Regards, BlueVM Support Team https://bluevm.com
BlueVM
@WebSearchingPro - Sometime in in the middle of August probably. Working on the KVM module right now, but KVM is more complicated than openvz (shock) so I'll need a few more weeks to finish it.
Looking forward to the new panel.
Even if I have to wait a little longer due to my KVMs.
BlueVM
@WebSearchingPro - While we used the same design and some of the same framework Neon and Feathur are two entirely seperate projects. Neon is a Webhosting control panel like cPanel and Feathur is a VPS control panel. They may look similar, but underneath they're designed to do two different tasks.
Magiobiwan
Insert Witty Statement Here
And it was easier to use the same basic visual themes for both. Plus they look the same, so its easier to tell they were made by the same person.
WebSearchingPro
VPS Peddler
Ahh okay, thanks for the clarification; So since their visually similar that's the closest I got to a screenshot.
