Latency monitoring of common DCs and hosts
WebSearchingPro
VPS Peddler
BHS = Beauharnois, Canada
CHI = Chicago, Illinois
DAL = Dallas, Texas
LAX = Los Angeles, California
LHR = London
MIA = Miami, Florida
Thanks @Damian, and @Zach, for lhr/bhs respectively!
Hopefully this helps someone who may not know!
Zach
bhs = ?
chi = Chicago, Illinois
dal = Dallas, Texas
lax = Los Angeles, California
lhr = London
mia = Miami, Florida
I'm not familiar with bhs, what would this be? Thanks! - Google turned up no conclusive results.
Thanks @Damian, for lhr!
Beauharnois, Canada = BHS (OVH)
Anybody else getting a huge amount of traffic from them? We're seeing over 120Mbps in/out for the past few hours. Not sure why but hopefully they resolve it soon or we'll have to start blocking their IPs at the router. :(
scv
Massive Nerd
+ anyNode
title = anyNode (Multiple)
menu = anyNode (Multiple)
++ LocationOne
title = anyNode Detroit
menu = Southfield, MI
host = 67.214.115.92
++ LocationTwo
title = anyNode Chicago
menu = Chicago, IL
host = 216.107.159.5
kaniini
Beware the bunny-rabbit!
To clarify: Our monitoring activities are using less than 5mbps in aggregate across 1000 hosts.  KuJoe reached out to me in PM and we sorted out the confusion (I believe anyway).
(If it took 120mbps to monitor a host we would not be operating this.)
Yes, the problem was on our end. :)
kaniini
As a general advisement, the BHS probe will be retired at some point between August 1 and August 31.  This is, of course, related to our pull-out from OVH.
InfiniteTech
Here you go:
+ Infinite Tech
title = Infinite Technologies Limited (Amsterdam, The Netherlands)
menu = Infinite Tech (Amsterdam, The Netherlands)
host = 91.215.158.158
fred.kard
Dear All,
I'm trying to install smokeping slave on raspberry pi.
After sudo apt-get install smokeping done, i'm running the smokeping with this command ==>
" sudo /usr/sbin/smokeping -master-url=http://10.10.10.23/cgi-bin/smokeping.cgi -cache-dir=/var/smokeping/ -shared-secret /var/smokeping/secret.txt "
Then this error comes up ==>
"WARNING: Opening secrets file /etc/smokeping/smokeping_secrets: Permission denied
ERROR: we did not get config from the master. Maybe we are not configured as a slave for any of the targets on the master ?
this is file permission of /etc/smokeping/smokeping_secrets ==>
pi@raspberrypi ~ $ ls -lrt /etc/smokeping/smokeping_secrets
-rw-r----- 1 smokeping smokeping 59 Mar 17 2013 /etc/smokeping/smokeping_secrets
anyone can give me a clue what is going on ? I have change the permission with chmod 400 and chmod 600 with no luck.
thanks before
