USB Temperature Sensor / Probe with Linux Compatibility
Anyone out here doing any work with USB attached temperature sensors / probes?
Looking for gear recommendation for USB temperature sensor / module / etc.   Prefer something finished, in a case aside from maybe a probe arm.
Linux compatibility is the key here.
Anyone using such a device or can recommend one? (not interested in raw Raspberry Pi io-style modules/projects).
pcan
I had very good results from Yocto-thermocouple http://www.yoctopuce.com/EN/products/usb-environmental-sensors/yocto-thermocouple. Very good software support for any OS, including Linux. This USB interface is supplied with two basic (and flimsy) thermocouples. In my application I used standard rugged industrial thermocouples to measure the burning chamber temperature of a owen. The temperature data is then stored on a mysql database to plot the temperature profile of each burning cycle. The owen must reach a specific temperature to break down hazardous chemicals, so reliability is the key of this application, because a missing record could be fined.
Yocto makes AWESOME stuff.
Totally great recommendation!!!
TurnkeyInternet
We've used IT Watchguard devices, it's not USB but you mentioned external - and this is simply a stand alone network / tcp-ip device that sends you the alert.
http://www.itwatchdogs.com/
We have clients who use them in their own racks to monitor things in addition to what we already do with our central system.  It's a good 1-off monitor device for a single client.
