It is easy to run your website on different servers.
It is easy to run databases accross different servers.
Because virtual servers got quite cheap.
But it is not that easy to ensure that your visitors are visiting a server that is still running.
You can setup more than one A record but a lot of browsers do not support DNS load balancing.
You can setup a load balancer but then you just moved the problem to another place. You load balancer is now the single point of failure.
For me DNS looks like a good solution to point visitors to the right server.
During the next weeks I will add more complex scenarios on how to handle DNS failover.
But I want to start with a low effort and simple solution.
Afterwards more tools and servers are added to the setup.
So everyone can decide how much effort he/she wants to put into his/her own DNS failover system.
So lets start with the first step into DNS failover.
1. Create a DNS server account which is supporting dynamic DNS updates
For me HE.NET is offering a cheap ($0.00) and reliable DNS service.
If you add an A record you can select that this record can be dynamically updated through a script:
TTL (time to live) for this can be setup to up to 5 minutes.
Quite a short amount of time for a free service.
After the creation you have to click on the arrows on the right side to add your access key.
This will be your password to update the A record. [The values are not real - so don't try them.]
Best addon it is working for AAAA (IPv6!) too:
The update of the ip is simple:
curl "https://dyn.dns.he.net/nic/update?hostname=dyn.example.com&password=password&myip=192.168.0.1"
curl "https://dyn.dns.he.net/nic/update?hostname=dyn.example.com&password=password&myip=2001:db8:beef:cafe::1"
Just use curl to call a url.
2. Write a short bash script that is managing everything
So what do we need?
I am using just bash, curl and dig.
Dig ist part of the dnsutils and can be installed through following command:
sudo apt-get install dnsutils
After that we can create the file containing the ips:
nano ~/ips
Content:
127.0.0.1
186.0.0.1
10.1.1.1
So one ip per line. I am using the order to priorize the servers because the script is taking the first usable ip to update the DNS record.
Now we can create the bash file:
nano ~/dnsupdate && chmod +x ~/dnsupdate
Content:
#!/bin/bash
IFS=$'\n' read -d '' -r -a ips < ~/ips
statusweb=()
index=0
echo "=================================="
echo "check following ips"
echo "${ips[@]}"
for i in ${ips[@]}
do
echo "checking $i"
let index=index+1
if curl -m 5 -s -k --head --request GET $i | grep "200 OK" > /dev/null
then
statusweb[index]=true
echo "================="
echo "web ip is up"
else
statusweb[index]=false
echo "web ip is down"
fi
done
echo " "
echo "update dns"
echo " "
index=0
for statuswebval in ${statusweb[@]}
do
if $statuswebval
then
echo "Changing web DNS..."
oldip=$(dig +short test.domain.com)
echo "current ip: ${oldip}"
echo "new ip: ${ips[$index]}"
if [ "${ips[$index]}"=="$oldip" ]
then
echo "update not needed"
else
curl "https://dyn.dns.he.net/nic/update?hostname=test.domain.com&password=astromgpassword&myip=${ips[$index]}"
echo "update done"
fi
break
else
echo "Skipping ${ips[$index]}"
fi
let index=index+1
done
echo "end of script"
So what is this script doing?
[*]loop through the status values
[*]done
Last step is creating a cron job calling this script every 5 minutes:
crontab -e
Add line:
/5 * * * * /usr/bash ~/dnsupdate
I think this is the bare minimum setup to check webservers and update DNS records.
So let's talk about some disadvantages:
As always I am looking for feedback, improvements and other solutions.
Next step is to add CloudFlare support.
First thing you need is the API-KEY, which can be found on the buttom of your Account information.
The API itself is easy, but is using JSON.
So we need some Ruby magic to get this done.
nano dnsupdate.rb
Content:
require 'json'
domain = ARGV[0]
ip = ARGV[1]
id = ""
listResponse = `curl [parameters 1]`
puts listResponse
domains = JSON.parse(listResponse)
domains['response']['recs']['objs'].each do | domainrecord |
puts domainrecord
if (domain == domainrecord['name'])
id = domainrecord['rec_id']
break
end
end
updateResponse = `curl [parameters 2]`
status = JSON.parse(updateResponse)
puts status
if status['result'] == 'success'
puts "update done"
else
puts "error during update of #{domain}"
end
So what are we doing?
You have to set the results to "public access" to enable the script to download the ping results without an API key.
This is my Ruby script that catches the ping results from nodeping, checks the number of network failures, and sets the ip which is a) currently online and B) does have the lowest number of failures as the new value of the A record of the given domain:
require 'json'
require 'date'
class NodePingResult
attr_accessor :ip, :isup, :numberOfBadResults
def to_s
"#{@ip} #{@isup} #{@numberOfBadResults}"
end
end
nodepingReports = []
nodepingIPs = []
nodePingResults = []
recordId = ""
ip = ""
#Please change you cloudflare and nodeping information
domain = 'mydomain'
cloudflaretoken='QWERTZUIOP'
cloudflarelogin='[email protected]'
nodepingReports << 'https://nodeping.com/reports/results/[reportid]/50?format=json'
nodepingIPs << '127.0.0.1'
nodepingIPs = nodepingIPs.reverse
counter = 0
nodepingReports.reverse_each do | report |
res = NodePingResult.new
res.ip = nodepingIPs[counter]
res.numberOfBadResults = 0
reportResult = `curl #{report}`
results = JSON.parse(reportResult)
results.each do | result |
if ('Success' == result['m'])
res.isup = true
else
res.isup = false
res.numberOfBadResults += 1
end
end
counter += 1
nodePingResults << res
end
nodePingResults.sort! { |a,b| a.numberOfBadResults <=> b.numberOfBadResults }
nodePingResults.each do | newip |
if (newip.isup == true)
ip = newip.ip
break
end
end
puts "selected ip: #{ip}"
parameterDomainList = "-d 'tkn=#{cloudflaretoken}' -d 'email=#{cloudflarelogin}' -d 'z=#{domain}'"
listResponse = `curl https://www.cloudflare.com/api_json.html -d 'a=rec_load_all' #{parameterDomainList}`
#puts listResponse
puts domainrecord
recordId = domainrecord['rec_id']
break
end
end
puts recordId
parameterDomainUpdate = "-d 'tkn=#{cloudflaretoken}' -d 'id=#{recordId}' -d 'email=#{cloudflarelogin}' -d 'z=#{domain}' -d 'type=A' -d 'name=#{domain}' -d 'content=#{ip}' -d 'service_mode=1' -d 'ttl=1'"
updateResponse = `curl https://www.cloudflare.com/api_json.html -d 'a=rec_edit' #{parameterDomainUpdate}`
#puts status
puts "update done: #{domain} now pointing to #{ip}"
else
puts "error - check last response: #{status['msg']}"
end
The script has to loop through the ping results in reverse order because the list starts with the newest entry first.
Due to the lack of API access you have to enter the ip address of each nodeping test.
And for the people who don't want to use Ruby - the bash only version of the script:
1. Create list of ips to check
nano ~/ips
Content:
127.0.0.1
186.0.0.1
10.1.1.1
2. Create list of node ping tests for the given ips (same order)
nano ~/results
Content:
https://nodeping.com/reports/results/[id of test]/100?format=json
3. Install libs:
sudo apt-get install dnsutils curl jq
If jq is not in the repos you can install it yourself:
#32bit version
wget http://stedolan.github.io/jq/download/linux32/jq && chmod +x jq && cp jq /usr/bin
#64bit version
wget http://stedolan.github.io/jq/download/linux64/jq && chmod +x jq && cp jq /usr/bin
4. Create bash script:
nano dnsupdate && chmod +x dnsupdate
Content:
#!/bin/bash
#Configuration
domain="domain.com"
recordId="#"
cloudflarelogin="cloudflare-login"
cloudflaretoken="cloudflare-token"
#Files
IFS=$'\n' read -d '' -r -a iplist < ~/ips
IFS=$'\n' read -d '' -r -a results < ~/results
statusweb=()
statuspoints=()
index=0
echo "check following ip list with nodeping"
echo "${iplist[@]}"
for i in ${iplist[@]}
do
echo "checking $i"
$(curl -m 5 ${results[index]} -o "./res${i}")
resultstring=$(cat "./res${i}")
statuspoints[index]=$(cat "./res${i}" | grep -Po '"m":.*?[^\\]",' | grep Success | wc -l)
resultstring=$(cat "./res${i}" | grep -Po '"m":.*?[^\\]",' | head -n 1)
if [ "${resultstring}"=="\"m\":\"Success\"," ]
then
statusweb[index]=1
echo "web ip is up"
else
statusweb[index]=0
fi
echo " "
echo "status: ${statusweb[index]}"
echo "status: ${statuspoints[index]}"
echo " "
let index=index+1
done
max=0
counter=0
indexselectedip=0
for point in ${statuspoints[@]}; do
if (( point > max && statusweb[counter] == 1 )); then
max=$point
indexselectedip=$counter
fi
let counter=counter+1
done
parameterDomainList="-d a=rec_load_all -d tkn=${cloudflaretoken} -d email=${cloudflarelogin} -d z=${domain}"
domaindata=$(curl https://www.cloudflare.com/api_json.html ${parameterDomainList} -o domainlist)
key=$(cat domainlist | jq '.response.recs.objs[] | {name, rec_id} ' | cut -d ':' -f 2 | grep \" | sed 's/"//g' | sed 's/ //g' | sed 's/,//g' | tr '\n' ' ' )
domainlist=( $key )
echo "checking domainlist: ${domainlist[@]} with cloudflare"
for ((i=1; i < ${#domainlist}; i++))
do
echo "#${domainlist[$i]} ${i}"
if [[ "${domainlist[$i]}" == "${domain}" ]]
then
let k=i-1
recordId="${domainlist[$k]}"
echo "break for: ${recordId}"
break
fi
let i=i+1
done
echo " "
echo " "
echo "update dns"
echo " "
oldip=$(dig +short ${domain} | head -n 1)
sleep 2
echo "new ip: ${iplist[$indexselectedip]} (points: ${statuspoints[$indexselectedip]})"
tester=${iplist[indexselectedip]}
if [[ "${tester}" == "${oldip}" ]]
then
else
parameterDomainUpdate="-d act=rec_edit -d a=rec_edit -d tkn=${cloudflaretoken} -d id=${recordId} -d email=${cloudflarelogin} -d z=${domain} -d type=A -d name=${domain} -d content=${iplist[indexselectedip]} -d service_mode=1 -d ttl=1"
cloudflareresponse=$(curl https://www.cloudflare.com/api_json.html ${parameterDomainUpdate})
echo "response: ${cloudflareresponse}"
echo "update done"
fi
So what are we doing here?
[*]Load list of DNS records for domain from cloudflare
[*]Search for domain record we want to update
[*]dig domain to get current ip
[*]compare current ip with the one with the best uptime and score
So what do we need?
- A textfile containing ip addresses of the web servers
- A way to check which servers are online
- A call to HE.NET to update the DNS A record
nano ~/ips
Content:
127.0.0.1
186.0.0.1
10.1.1.1
Content:
#!/bin/bash
statusweb=()
index=0
echo "${ips[@]}"
for i in ${ips[@]}
do
echo "checking $i"
let index=index+1
then
echo "web ip is up"
else
fi
done
echo " "
echo "update dns"
echo " "
index=0
do
if $statuswebval
then
then
else
echo "update done"
fi
break
else
fi
let index=index+1
done
- read the list of ips into an array (ips)
- create two empty arrays (statusweb,index)
- echo the list of ips
- loop through the ips
for each ip do
add 1 to index (let is cool) - curl the http header of the webservice running on the ip and check if it is 200
Timeout is set to 5 seconds to ensure the script is not locked. - curl is returning true or false so it can be part of an if statement
- we store the status of the ip with a true or false value in the array statusweb
- for each status do
dig the DNS record you want to update
+short ensures that only the ip is returned - compare the ip of the DNS record with the first ip which is working
- update the DNS record or skip it
[*]done
crontab -e
Add line:
- Webservers are only checked from one internet connection
So you cannot be sure if the server is offline for the all visitors or only for you - There is no history record for the reliability of one ip
So you cannot be sure that you select an ip that is currently up but does only have an update of 80%
You can try to manage that by sorting the list of ips but you have to keep the records for that too. - If you use more than one vps to run this script it might happen that the different scripts will overwrite the results of other scripts.
So if you have a network split or more than one routing issue the DNS record is flipping around.
nano dnsupdate.rb
Content:
require 'json'
domain = ARGV[0]
ip = ARGV[1]
id = ""
puts listResponse
puts domainrecord
break
end
end
puts status
puts "update done"
else
end
- save the two parameters to the vars domain and ip
- Call curl to get the list of domains and DNS records
- Pars the JSON response to find the correct record for the given domains
In this example I want to update the A record for the domain itself - If the record is found save the id of the record (needed for update)
- Send the update request via curl
- Check the status to ensure that the update is done
- list domains and records
curl https://www.cloudflare.com/api_json.html \
-d 'a=rec_load_all' \
-d 'tkn=[Your API_TOKEN]' \
-d 'email=[Your CloudFlare login]' \
-d 'z=[domain to update]'
- update domain
TTL is the time to live of record in seconds. 1 is the value for the "Automatic" setting.Code:curl https://www.cloudflare.com/api_json.html \ -d 'a=rec_edit' \ -d 'tkn=[Your API_TOKEN]' \ -d 'id=[DB ID of the record you want to update]' \ -d 'email=[Your CloudFlare login]' \ -d 'z=[Domain of record]' \ -d 'type=A' \ -d 'name=[Name of record to update]' \ -d 'content=[new ip address]' \ -d 'service_mode=1' \ -d 'ttl=1' \
require 'json'
require 'date'
def to_s
end
end
nodepingIPs = []
recordId = ""
ip = ""
domain = 'mydomain'
counter = 0
res.isup = true
else
res.isup = false
end
end
counter += 1
end
ip = newip.ip
break
end
end
#puts listResponse
puts domainrecord
break
end
end
puts recordId
#puts status
else
end
nano ~/ips
Content:
127.0.0.1
186.0.0.1
10.1.1.1
nano ~/results
Content:
3. Install libs:
#32bit version
#64bit version
Content:
#!/bin/bash
#Configuration
domain="domain.com"
recordId="#"
#Files
statusweb=()
statuspoints=()
index=0
echo "${iplist[@]}"
do
echo "checking $i"
then
statusweb[index]=1
echo "web ip is up"
else
statusweb[index]=0
fi
echo " "
echo " "
let index=index+1
done
max=0
counter=0
indexselectedip=0
max=$point
fi
done
domainlist=( $key )
do
then
let k=i-1
break
fi
let i=i+1
done
echo " "
echo " "
echo "update dns"
echo " "
sleep 2
then
else
echo "update done"
fi
- Load list of ips and nodeping tests
- Check results for each ip
count number of good results to check quality of host - check current status of ip
- update dns record
- or do nothing if the record is allready pointing to the best ip
