jarland
The ocean is digital
Situational, but a host should absolutely be monitoring processes. Not like snooping on a VPS but when you get an alert, which could be from anything not necessarily you, you start looking at what is slamming the node. If you're up there, damn right they're going to see the process on OpenVZ. You're not hidden from top and iotop, your processes are right there and they need to know what is running hard when the node is tanking. If you fit the bill as a part of the problem, expect to hear it, unless you're on a provider that doesn't care. Some may even choose not to talk to you about the specifics, but rest assured on OpenVZ...they see them.Sure, but a normal host should not be monitoring what processes you are running unless you get an abuse report.
I guess you can think of it this way, for someone buying a 4GB RAM server, it should be able to handle 3GB of RAM, so my usage to test the RAM seems legitimate. For someone who buys a server with 250GB of space and tries to transfer over all their files from another host would need to transfer at 4MB/s for 18 hours in order to start using the service, so downloading a 100GB file at 4MB/s seems legitimate to me.
