ModulesGarden Proxmox VPS 1.3 For WHMCS With Tons Of New Features!
ModulesGarden Proxmox VPS For WHMCS allows you to automatically provision virtual servers to your customers who can manage them directly from your WHMCS client area. Module also contains Proxmox Addon where you can monitor & manage your servers, IP addresses and clusters.
Version 1.3 contains many new features and improvements made according to your requests and our own ideas.
Tomorrow we will release Proxmox Cloud For WHMCS 1.1 with many new functionalities too. Keep your eye on our social networks where we will present more details.
Changelog:
  • New Feature: Integration with IP Manager For WHMCS
  • New Feature: Backups routing
  • New Feature: New configurable options : 'IPv6 Address', 'VM Template' and 'ISO Image'
  • New Feature: KVM templates creation from Proxmox For WHMCS addon
  • New Feature: Assignment of IP addresses to selected virtualization at the Proxmox For WHMCS addon
  • New Feature: Task history
  • New Feature: Node name at the client area
  • New Feature: Synchronize templates
  • New Feature: Change hostname (OpenVZ virtualization)
  • New Feature: Cron (boot of recently created VM and reinstall of VM from template)
  • New Feature: VLAN Tags (KVM virtualization)
  • New Feature: Custom IP address for console
  • Changed: Graph moved to a separate page at the client area
  • Changed: Configurable option name from 'IP Addresses' to 'IPv4 Addresses'
  • Fixed: Missing backups after reinstallation
  • Fixed: 'Authentication' replacing 'Access Hash' at other modules
  • Fixed: Backup jobs & sheduled tasks not removed during VM termination
  • Minor bug fixes
Admin Area Features:
  • Create Server
  • Suspend/Unsuspend Server
  • Terminate Server
  • Change Package (Supports Configurable Options
  • Boot Server
  • Reboot Server
  • Stop Server
  • Reinstall Server
  • View Server Status, Details And Statistics
  • View Graphs (With Ability To Change The Time Scale of MRTG Graphs)
  • Display Disk And Bandwidth Usage Of Each Product
  • VNC Console Access
  • Auto Node - Possibility To Automatically Create VM On The Node With The Most Free Space
  • Possibility To Import IP To Hosting IP Addresses Table
  • Possibility To Return IP To IP Addresses Pool
  • Possibility To Add Additional IP To VM
  • Configuration Of Features Available At The Client Area
Proxmox Addon Features:
  • Servers List
  • IP Management (Per Server)
  • Clusters (Per Server)
  • KVM Templates
Client Area Features:
  • Boot Server
  • Reboot Server
  • Stop Server
  • Shutdown Server
  • Reinstall Server
  • VNC Console
  • Create Backups
  • Restore Backups
  • Backups Routing
  • Backup Jobs
  • Task History
  • Backup Files & Job Limits (Max Number Of Files & Max Size Of Files)
  • Easy Product Upgrade/Downgrade
Additionally:
  • Supports PVE And PAM Autentication
  • Dynamically Chosen Server Resources While Ordering And Possibility To Upgrade Those Resources
  • Integrated With Advanced Billing For WHMCS - Server Resource Usage Billing (read more)
  • Integrated With IP Manager For WHMCS – Complete Management of IP Pools (read more)
  • Multi-Language Support
  • Supports Proxmox VE 3 and Later
  • Supports IPv4 and IPv6
  • Supports WHMCS V5 and Later
Available Configurable Options For KVM:
  • The Number Of CPU Sockets
  • The Number Of Cores Per Socket
  • CPU Weight For A VM
  • Amount Of RAM
  • Disk Space
  • Network Rate
  • IPv4 Addresses
  • IPv6 Addresses
  • Backups Limit
  • Backups Files Limit
  • Bandwidth Limit
  • VM Template
  • ISO Image
Available Configurable Options For OpenVZ:
  • Amount Of SWAP
  • Amount Of RAM
  • Disk Space
  • IPv4 Addresses
  • IPv6 Addresses
  • Backups Limit
  • Bandwidth Limit
  • VM Template
Are You Interested?
✔ Order Proxmox VPS For WHMCS Now!
Do You Need More Information?
✔ Read More About Proxmox VPS For WHMCS
Are You Looking For Complete Documentation?
✔ Visit Proxmox VPS For WHMCS Wiki
Coming Next:
  • Proxmox Cloud For WHMCS 1.1 - 17.04.2014
  • Multibrand For WHMCS! - 23.04.2014
  • Updates of SolusVM VPS & Cloud For WHMCS
  • Asterisk VoIP Center For WHMCS
  • Softlayer For WHMCS
  • Report Generator 1.5
  • Domain Orders Extended For WHMCS 2.0
  • Domains Reseller For WHMCS 1.5
  • Time Tracking Center For WHMCS - this module will allow you to sell hours of work (e.g. 10 hours of support per month), bill for time spent on a certain job and bill for overage.
We have just released Proxmox Cloud For WHMCS 1.1. This might also interest you.
The module allows your customers to create and manage their own virtual servers at virtual datacenters in your WHMCS client area. You set the resource limit and your clients create any number of servers within the purchased limit!
Version 1.1 is full of new, exciting features and important improvements.
Along with update of Proxmox Cloud For WHMCS, we release IP Manager For WHMCS 1.6.2 which is integrated with Proxmox VPS & Cloud.
Changelog:
  • Minor bug fixes
✔ Read More About Proxmox Cloud For WHMCS
✔ Visit Proxmox Cloud For WHMCS Wiki
