Yes, that sounds about right, but the cost of a few PIs is most likely cheaper then a desktop.So if you want one unit to control all monitors the PI is out and a desktop it is? Is that a correct assumption?
Depending on the infrastructure and company policy and if you could find other uses, a desktop could still be the right choiceYes, that sounds about right, but the cost of a few PIs is most likely cheaper then a desktop.
@willie, how were those mk808's? Work well? Long been interested in them / newer models. Haven't tinkered with one yet.My old office did that with cheap Android sticks (search for "mk808")
The ones we had worked pretty well in 720p. There was a suspicious-looking firmware upgrade for 1080p that required running some equally suspicious binary blob under Windows to load the firmware into the stick, so I never ran that. It might be possible to find the source for that thing. I spent a little while looking without success, but with more persistence it might turn up. There are several makes/models of the mk808 and there's some newer ones now, so shop around.@willie, how were those mk808's? Work well? Long been interested in them / newer models. Haven't tinkered with one yet.
Yup - one Pi - one monitor.So if you want one unit to control all monitors the PI is out and a desktop it is? Is that a correct assumption?
Cool project indeed, my mind was on a multiple monitor setup with something more in the line of network or client monitoring. Example: a website /monitor showing statistics or client information.
I suspect OP has spare monitor(s) hanging out like most of usWhy don't you use the new smart-TV's this has an build in browser, just point this at your status page, full screen, done
That is awesome! I also have not had the time to play with a Raspberry Pi yet, but this makes me want to buy one right away.I use my RPi with my 27" monitor without any issue. I mostly run RPITC (Raspberry Pi Thin Client) and my Windows 7 VMs are hosted in various DCs around the country (locally hosted would be MUCH better but under 20ms is still usable).
Here's a video of my RPi connected to a VM in Virginia: http://www.youtube.com/watch?v=XpoflazJ-Pg
* 1.7GHz Quad-Core processor and 2GByte RAM
* 10/100Mbps Ethernet with RJ-45 LAN Jack
* 3 x High speed USB2.0 Host ports
* Audio codec with headphone jack on board
* XUbuntu 13.10 [SIZE=10pt]or [/SIZE][SIZE=10pt]Android 4.x Operating System[/SIZE]
* Size : 83 x 48 mm, Weight : 48g including heat sink
* Package includes the main board and the heat sink
Yeah, that looks pretty awesome at the price.How about this ? http://hardkernel.com/main/products/prdt_info.php
$59 / Quad-Core / 2 GB RAM / 1080p HDMI out
No. There is no point as it is not practical in anyway especially when you compare costs to an actual backup node device/system.On a side note, has anyone tried using a Pi as a local backup node?
Yes - it works perfectly fine with a drive attached.On a side note, has anyone tried using a Pi as a local backup node?
With a external usb 2 disk? No!On a side note, has anyone tried using a Pi as a local backup node?
