Dear All,
I'm trying to install smokeping slave on raspberry pi.
After sudo apt-get install smokeping done, i'm running the smokeping with this command ==>
" sudo /usr/sbin/smokeping -master-url=
http://10.10.10.23/cgi-bin/smokeping.cgi -cache-dir=/var/smokeping/ -shared-secret /var/smokeping/secret.txt "
Then this error comes up ==>
"WARNING: Opening secrets file /etc/smokeping/smokeping_secrets: Permission denied
ERROR: we did not get config from the master. Maybe we are not configured as a slave for any of the targets on the master ?
this is file permission of /etc/smokeping/smokeping_secrets ==>
[email protected] ~ $ ls -lrt /etc/smokeping/smokeping_secrets
-rw-r----- 1 smokeping smokeping 59 Mar 17 2013 /etc/smokeping/smokeping_secrets
anyone can give me a clue what is going on ? I have change the permission with chmod 400 and chmod 600 with no luck.
thanks before
