Piwik "Load Data Infile"
fahad
I have been using piwik for some time and i got that super useful. Except one error i get in System Check. I am just curious what does it says.....
What is that Thing and how to solve this ?
Note:That Database user is not root,created by ispconfig.
wcypierre
do remember to set the privileges off if piwik has a SQL Injection vulnerability or the attacker will be able to read or even worse write files at/to your filesystem :)
wcypierre
Then I will Stick with the error ! :p
multiple one insert/update for 10k of records is seriously slow, while it is much much faster if you aggregate it as one or a batch of hundreds or thousands, but infile is :D
I didn't realized that the overhead was this big until I've started to write a data scrapper for a dictionary site. hell, one insert is hell slow........ batch insert is much faster, and I don't think that I'll have to explain the last one, no?
Anyway, not to say that its bad though, if you're h aving a heavy traffic then may as well as enable it. Just be more aware of the security part and you'll be fine
fahad
Nice Suggestion . I will try for once i think. Thank You .
