Cloudflare problem?
I'll look into adding some free ones as alternative options.More themes for us to choose from?
http://www.finalprestige.net/index.php?p=3&product=150
Looks nice. You can leave it as default as the current theme and just add more for us to pick from at the bottom of the website using change theme.![]()
This.Cloudflare problem?
I'm going to ditch CF as soon as I can afford a proper CDN.Cloudflare bot-control makes posting code really annoying. I eventually gave up on it.
This I have been asking for a while. I can understand the budget limitations could be a reason.More themes for us to choose from?
Like what?What I wish for this community is to have something unique that will set it apart from LET
Take a look at Google Page Speed service. Its plug and play just like cloudflare but infrastructure is greater than CF of courseI'm going to ditch CF as soon as I can afford a proper CDN.
Seems like both may have been a cookie issue. Tried the site on a different computer and it worked fine.A couple of issues: first, Google search of the forums seems to have disappeared. Second, I can't stay logged in. I have to log in again every time I visit the site, even though I check "Remember me". It seemed to happen right after I changed my password to a randomly generated one with non-alphanumeric characters, and is still happening even after I've changed it back.
You hit your head on the nail.Seems like both may have been a cookie issue. .
You can modify this from your control panel. Anyone with 150 posts or more can do this now.Is it only providers (and admins of course) that are able to change their "member title" (e.g. mine is "VPS Enthusiast")? I don't see any place to do it.
Ban people that make stupid suggestions.
+1Define stupid suggestions.
I'd personally put this under stupid suggestions.
I literally made that post with the intention to get a reply along the lines I received.Define stupid suggestions.
Hi took you long enough to join this place I told Francisco to tell you to join this one since it lacked Joel and stuff.@Naruto,
You are the still the same person! It is good to see that you haven't changed.
