What do you use your Raspberry Pi for?
So far just been using it to get frustrated at network bridging attempts. I've got both machines capable of pinging back and forth, can SSH back and forth locally, but trying to get the Pi to connect to the internet by sharing the WiFi connection of the PC it's wired to and all hell breaks loose.
Though while typing this I just thought of an idea that may just work...
Sorry to bump an old(ish) thread, but I want this case!
http://shop.pimoroni.com/collections/pibow/products/pibow-timber
NodeBytes
Dedi Addict
I just bought a Raspberry Pi. Planning on using it for logging functions as well as some software defined radio projects.
I've setup a Windows 7 KVM on our new KVM node in Denver and the RPi with rdesktop is amazingly smooth. I'm running PiBang right now because I was doing some actual work but I'm going to switch over to RPITC to see how it runs without any extras in the background.
Jeffrey
Very nice setup, Kujoe!  Glad to see you here at VPSBoard also, I was wondering why you left LET.
rm_
You can't bridge WiFi to anything if you're just a WiFi client. Only the AP can bridge.
Very annoying, but that's how it was designed. Google around if you want to know details.
An alternative would be to set up routing+NAT on the PC, not bridge.
Actually, I now have access to the router so I have the Raspberry Pi can connect to it directly now. Need to reflash the OS, as some updates recently rendered the device unbootable. Boo.
I've got some ideas, but not had time to do anything yet.
Got motivated earlier, re-flashed my SD card and installed a local webserver. Looking for a pre-configured solution so I didn't have to strip down the stock Raspian install, I found this: http://coburndomain.net/forums/topic/249-raspberry-server-20/ Basically a minimal Debian distro with Nginx, php5-fpm and MySQL.
Since it's documented pretty poorly, I'll just list some basics below:
Download and extract the .img file: https://mega.co.nz/#!gU5W2S4D!FbwYuUTf_zJxrW-gFDTbMzaDY9Y4vWYIayymyneKfrg
 and flash your SD card:
dd bs=4M if=~/RaspberryServer2_Foundation_21062013.img of=/dev/sdc
(Thats assuming your SDCard is /dev/sdc and that you're using the same build I am.
After that, setup was a breeze. Slide that SD card into your Raspberry Pi, wire your Raspberry Pi to your router and plug it in. After that all you have to do is figure out what IP your Raspberry Pi has locally, so run:
nmap -p22 -sV --open 192.168.1.0/24
Which resulted in (for me, may be different for you):
Starting Nmap 6.00 ( http://nmap.org ) at 2013-08-06 04:17 EDT
Nmap scan report for 192.168.1.108
Host is up (0.00085s latency).
PORT STATE SERVICE VERSION
22/tcp open ssh OpenSSH 6.0p1 Debian 4 (protocol 2.0)
Service Info: OS: Linux; CPE: cpe:/o:linux:kernel
Service detection performed. Please report any incorrect results at http://nmap.org/submit/ .
Nmap done: 256 IP addresses (5 hosts up) scanned in 4.57 seconds
So now I could SSH into my Raspberry Pi with using 'root' and the default password of 'raspberry'.
I was able to confirm it was working by going to: 192.168.1.108 in my browser on my desktop PC and getting the default webserver page.
Stock install takes up about 50MB of RAM, so it's already pre-configured/tuned for the most part.
Anyhow, I messed around for a bit, set things up as I normally would for a LEMP stack. Running a ServerBear benchmark on it right now, haha. I'll post those results when they become available.
It's been 2 days, is it still running? :p
rm_
If you want I/O performance, you should have got a Cubieboard, it has a SATA port.
Anyone doing anything new and fun with their Pi?
I am holding out on the Pi, being a disk speed type of person USB isn't going to cut it.  Cubies look more my speed, but Pi's seem to be getting all the love.
I used mine as my primary desktop while I waited for my new laptop (about 3 weeks due to a delay). I was very impressed with how well it ran when RDPing to Windows servers that were less than 50ms away. No loss in productivity. :D
stim
Haven't got one yet but I have a few ideas brewing:
-zombie backup machine using Bittorrent sync. I'm finished with the cloud.
-make a solar-powered music server with battery back-up.
-see if I can make a basic music synthesizer/MIDI sequencer.
-with camera as a timelapse creator.
